I got a 85 boat with a OMC 2.5 inboard and a OMC stringer 400 stern drive. The boat is leaking water through a finger size hole in the transom seal and there is no water coming into the thermostat housing. I pulled the 22 hole transom seal np, pulled it over the outdrive with np. I got the seal ordered. I need to replace the water pump/impeller. A few monthes back i put a water pump/impeller on a mercruiser 2.5 and a 3.0 both in the foot. Well i got ahead of myself and pulled the lower/foot, all i found was a sets of bearings and gears and a fat flat black wire that run from the upper into a gear housing of some sort. well i called and dealer and was told ther would be plate on the upper that has 4 bolts holding it on ( same plate/cover for upper oil check plug) so i removed the 4 bolts and tapped then proceded to beat then pry the cover off.......it is stuck solid.. after looking at some pics but still cant get it off. Any help on the easy/correct way would be killer. thanks alot.
