hello thanks for the previos help. the engine has 145 psi in all cylinders, but will not pump any water. the previous owner said it was just working. i put it in a barrel and run it and nothing. i blew air through the tell tail and bubblels came out in the barrel. i removed the brass plug between #2 and #3 cylinders and it looked like compression was puffing out. i took off the head water cover and did not see any cracks, and i spayed soap water in there and did not see any bubbles. i next took off the exhaust cover. all i found was a small area near one of the small passages going to the #2 cylinder corroded away, hard to really say for sure this was the problem. i have ordered the gaskets and a water pump kit. does any one have any ideas why there would be compression in the water jacket. i think the compression is keeping the pump from pumping water. thanks for any help dennis
