1985 Mercruiser 898 weight
mgreczek
Hi. I'm planning on pullun
Hi. I'm planning on pullung out Mercruiser 898 from my 1984 Scorpion 187. Could anybody tell me what weight should I expect? Thanks!
"Ayuh,...
If it's still
"Ayuh,...
If it's still Completely assembled,..??
I'd think it's in the 700/900lbs. range..."
If you are tight on lift capac
If you are tight on lift capacity you can pull the manifolds and risers to cut about 100 lbs or so.
Rod
Thanks for the quick response.
I think I should be fine with lifting. I have 1 ton chain hoist and 1 ton trolley. The only thing I still need to figure out is if I can use a steel beem in my garage. It looks like it is W12x40 with 21' span between posts. The thing is that beam already carries some of the second floor load. I need to do more reaserch on that beam. I just wanted to know what weight I would be adding.
"A W12 x 40 beam is pretty bee
"A W12 x 40 beam is pretty beefy.
I think you will find that it will handle a 700 lb point load just fine.
If possible, brace it up on either side of the boat hull with a 6 x 6 vertical wood post shimmed up tight. This will greatly cut down the unsuppoprted beam length and you should be good to go (lift).
Rod"
