1985 Johnson j60TLCOD 60hp overheating
tonypayette
I am new to MarineEngine forms but i can not figure out why my motor is overheating . I just bought the boat a mouth ago and took it out three times and the last time i was out the alarm started going off thought is might be to oil alarm at first so i unplugged it and still had the alarm witch lead me to the temp sensor i unplugged it and the alarm went off. So i ordered a new water pump and thermostat with the water jacket gaskets i just installed everything let the motor warm up and then the alarm goes of... while i had everything apart i blew out all the passages with air and water. the only thing that stuck out was the pressure relief valve seamed to be very sticky like it went in and out snug but i put it back in the way i took it out witch to me seemed backwards i blew air through the unit with it in the way i took it out and it did not move not even a little but if i flipped it around it worked great.. so long story short do you think that could be my problem??
I have a very good stream of water coming out of the tell tail but this model has the tell tail port coming out right where the water enters the block witch tells me nothing i have no idea if it is going all the way through the motor.
my other thought was to try it again flipping the pressure valve over the way i think it should go if that dose not work what would happen if i tried it without the thermostat in??
the block feels pretty hot to the touch i can not hold my hand on it for very long but i have not worked on an outboard in a long time so not sure what is too hot. I could really use some help thank you.
