David Dixon
Hello. I have a 1985 Johnson GT150. Model: J150STLCOH. The oil pump side of the VRO was disconnected before I bought the boat 6 years ago from a family member and oil has been premixed. The motor has intermittently cut out at high speed (over 4,000 rpm) since i have owned it. Last season it started to do it consistently and has been really hard to start first thing in the morning.
In the last couple of years, I have replaced the plugs, coil packs, had carbs rebuilt, replaced all fuel hoses and primer bulb, changed filter yearly, checked pickup tube screens, and checked compression (all 90-95). The primer bulb will not get hard when I pump it up. I would like to look into replacing the VRO pump and still premix. I have seen a dual pump conversion that is much cheaper. Should I go with that or get the more expensive VRO (non oiling) pump? Thanks in advance for advice!!
