My rebuilt engine was ran low on oil mix last time out and half way through the day it bogged down and stalled when given full throttle, and only let me idle speed going back to ramp, been running like a champ since 95 rebuild,
My compression tested 120 on each cylynder, which i hope is ok,
someone suggested the below does anyone concur?
Test #1 Start put in gear and take off until it starts to bog down, then
pump bulb rapidly
if it continues to stall then u have fuel pump diapram problem,
Test #2 Start put in gear and take off until it starts to bog down, thenpush
in choke if
it does not die then you have carborator problems,
pump bulb rapidly
in choke if
