Hello i have an 85 hp force its old but never let me down. will idle like a cylinder is missing. and wont plane and then it will run great for a little bit then run rough again. all in the same outing. then it will run perfect at times. compression was 127 119 and 124. if it was the low compression would it cause all the different running variations? and i did the compression test when cold. all 3 plugs get fouled up at one outing. swapped out an ignition coil on the middle low compression one. should i bother doing a fuel pump rebuild and the three carbs? or is the compression variance off to much? thanks for any suggestions. i also put in a marine carb cleaner around 10 tanks ago. and was using a new oil 50 to one as usual.
