My tilt and trim cylinders have a slow leak. Already purchased a rebuilt unit just waiting for the lift to assist in the install. For now though I really need to add some fluid to the system to limp her around. Never dealt with the tilt and trim on any boat. Where about is the fill? I know it needs to be all the way up, but where the hell is the fill?
Secondly I started the year off with a bad coil pack, replaced that, motor now firing on all 4 cylinders but doesn't want to idle anymore. Kicking it into gear will almost always kill the motor unless you give it a lot of gas right out of the gate. Checed float bowls and they were spotless clean. Sprayed some carb cleaner through the system with no effect. Could it be just a simple twist of a screw on the carbs?? any Ideas would be great. For some reason outboards scare me... I'm used to the standard V8's
Thanks Guys!
Thanks Guys!
