Thor Outlaw
1st post here
Hello everyone, I've got a low hours (300 hrs) 85 Evinrude V4 looper 140. The engine will run and idle (roughly) on all cylinders but the bottom port side. I've determined that there is spark. I get a 10mm jump easily. I can also determine that there is fuel at the plug. I figured it may of been wet fouled so I replaced all of them as well. Compression test shows 130lbs in the cylinder. Pulling one of any of the other 3 wires while running will stall the motor.
What I've done:
-Replaced all coils and wires with new
-Replaced all plugs
-Rebuilt all carbs
-Swapped carb from a working cylinder
-spraying wd40 in the bad cylinder carb while running will bog motor
-cleaned grounds for power pack
-ordered new power pack (it'll be here 7/21)
Can you guys think of anything else I may be missing? Im 11 months into this boat and have not gotten it in the water yet. Summer is burning here on Long Island and I'm itching to splash this thing.
What I've done:
-Replaced all plugs
-Rebuilt all carbs
