Hello all,
I recently purchased an '85 2hp evinrude that is in good running condition, I think. The guy I bought it from replaced the fuel lines and cleaned the carb, so it starts up fine. On my one and only outing with it it ran great and pushed me up river fine, but then on my way back down it started to bog and I had to keep adjusted the top knob to keep the RPMs up. What would cause this?
My next issue is that it would not stay at full throttle without me holding it in place. I see that there is a roller on the throttle that is supposed to go into a groove, but it seems to me like the groove isn't deep enough. Is there an easy fix for this?
And lastly, and mostly the reason for this post, it is not hanging in my garage and I noticed it is leaking gear oil from the lower unit fill plug. The problem I see is there is only 1 plug on the lower unit. No vent plug. So how do I go about changing the gear oil? Is it as simple as taking out the plug, tipping the motor till its empty, then re-filling while straight up till oil starts coming out the fill hole?
Thanks in advance for any help/advice!
