I have a 1985 90hp, all this year I have had a problem with it starting. At times it will turn over and over and won't start and then all of a sudden it starts when I just turn the key 1 time. an example from this past weekend-- started motor and went to first spot and fished, when I went to leave that spot it would not start and I tried for about 15 min. got mad and continued trolling along and about 45 min later I tried and it started right away and continued starting the rest of day. When it does not start I have disconnected the white eng. stop wire on motor and it still won't start. Could the pulsar coil cause this ( the readings on one set of leads is low) they want $400 for a new one and want to make sure before I spend that much money on a 25 year old motor.
I need some serios help with this one
