This is European motor with designation F9.9AM and 6G8 UL 702374 but doesn't seem to translate to U.S. model. Best I can figure it is basically model FT9.9EXK. I want to buy new carb but it is obsolete. So I am wondering if I can use the updated carb. My problems are that the automatic choke not working plus the screw for idle adjustment broken off carb body. I have adjusted the throttle control cable to get the idle correct for start up but choke not working. I am forced to start motor (motor converted to electric start) and wait for it to warm up before I can accelerate without stalling. Quite a pain!
The difference I believe is only the automatic choke apparatus. They changed the carb in 1992. I have seen the new carb and all looks the same except the automatic choke and the throttle adjustment linkage which isn't a problem. The 1992 would fit on my motor.
Here is my carb: http://www.boats.net/parts/search/Yamaha/Outboard/1985/FT9.9EXK/CARBURETOR/parts.html#
Here is the 1992 carb: http://www.boats.net/parts/search/Yamaha/Outboard/1992/T9.9EXHQ/CARBURETOR/parts.html
The new carb choke has a temperature sensor solenoid which wires to an engine temperature sensor. If my '85 has a sensor where this could be attached I don't know about it. Will this work?
So I am hoping to hear from anyone who understand this better than me. (that probably means anyone!)
Thanks.
Thanks.
