1985 85hp Force no spark on top hole
justboats
I have no spark on the top hole. It happened when I backed down from polling a tube and when I got the riders switched around and started to pole there was no power to do so. The motor never shut down so tested spark and nothing on the top. I moved the coils around and it did not move with it any help please thanks
Loss on the top plug: the trigger has extremely thin wires that break at the connector usually under the glue at the end.
Do the tug test on the wires at the buss bar where everything is connected.
The wire (if bad) will come out of the connector.
If you find one bad? replace all the connectors.
Loss: the pack can go bad and loose spark, swap them around and see if it follows the swap??
The following link has test procedures.
