1985 75hp Mercury lower unit
wayne1959
How should the shift follower be set when I slip the prop shaft in the gear case. My problem is once I get everything set and reassembled I have neutral and forward, but no reverse. And it seems to me like all the gears are in very good shape I'm wondering if it's a shift follower issue.
Thanks in advance!
Did you try getting reverse with lower unit off the motor ?-----Sorry --I cannot see how you are testing this.
Yes, I shifted it on the bench...it shifts into forward and back to neutral, then it shifts into reverse but the prop shaft won't engage in reverse.
