Progator135
Just got a 1985 Evinrude 50HP. Got it fired up and first thing I looked for was water from the telltale...little to none...revved and finally came very slowly. Pulled the LU and checked the impeller - blades were bent to shape but was still intact. Put water hose to the water tube in the mid-case and water came out but not at the rate I would expect with full hose pressure. Blew back through the telltale hose by mouth and felt some resistance. It would flow ok about the rate of a normal breath but felt some resistance when blew harder...Is this normal? I saw a post somewhere a while back where there were some water passage guides or blockoffs in the water jacket between the cylinders that get out of whack causing improper waterflow....can someone elaborate on this? Does this motor even have them? Or shut up and quit whining till I get a new impeller and check it?
