Long story, hopefully short.
I removed lower unit and gave to a retired mechanic who specializes in Johnson/Evinrudes to find source of shavings. Found few teeth chipped on pinion.
Found an issue with the tapered roller bearing on the shaft below impeller pump. The bearing that was installed had a broken outer race.
I ordered a new Timken, found that there's a lot of clearance between outer race and aluminum case. He ordered another bearing, same exact issue.
There's no obvious milling marks as if the bearing had spun or anything. It appears as if it's original surface.
Mechanic said he's never seen this in 40 years. He's stumped.
Anyone ever ran into this?
