"I have a 1985 40HP Mariner- n
"I have a 1985 40HP Mariner- not sure what is going on. When I crank the engine it will not stay running for very long. If I throttle it up it will stay running but it spits and sputters. I have unburnt fuel coming out of the exhaust (a grey goo)The thing is I have noticed that when I unplug the fuel line at the motor after about three seconds the motor will start to run perfectly (reve and idle) and no unburnt fuel out the exhaust! I then will plug the fuel line back on and in about three seconds it will start spitting again. It is like bogging the motor down or loading up to much fuel. I pulled my fuel lines and I found a pin hole in one of them (thinking this was the culprit) so I replaced all of the fuel lines. This did not help. I had just rebuilt my carbs last fall and it had been running fine up until this May when this started.I have just finished rebuilding them again and it still is doing the same thing. I am stumped. Good compression on both cylenders and good spark on both. I love this motor! I do not want to give up on it. It will run like a bat out of hell when its running right. Any helpful advise would be deeply appreciated. Thanks in advance,
Wilson Perry
P.S.- Also my top plug seems to fowl."
Wilson Perry
