I bought a Lund boat with twin 40 hp as the factory setup. The first thing I did was purchase the service manual. Then, I cleaned the carbs serviced the lower unit with new impeller kit and seals, replaced aged fuel lines, and serviced the electric trim as the fluid looked awful. They run great with great, even compression on all cylinders in both engines.
My only problem is that I can't get one of the engines to send a tach signal to the dashboard tach. If i switch plugs, I can get the other outboard to work on the other tach, so I know it is from the motor to the control.
While I think I do a pretty good job on the mechanical stuff, I never studied electrical and am really stumped as to where to begin. I figure that if I test the wrong thing or unplug something and try to run it, I could probably wreck something in the system. I can run with it the way it is, but when both are running, with my hearing, the tach is going to be the best way for me to see if something is going wrong before it totally quits.
Can anyone help direct me to a particular place to check? I have checked every connection on the engine and verified that they are connected tightly.
Thanks, in advance, for any and all help.
