chickenskinmusic
A newbie here and I need some
A newbie here and I need some help. Have a 1985 30 HP Johnson tiller steering. The water pump is the original and I have attempted to replace it with a new one. The impeller I bought came with a plastic key where as the original one had a small roller bearing to fit into the impeller.
The shaft on the motor has no slot for the key to fit in. Does the the plastic key simply ride against the rounded shaft and dies this turn the water pump. I am perplexed as to what makes the impeller turn when the motor starts. HELP! HELP!
