1985 3.0 no spark from coil to distributor
steverickey
It was running last summer when I shut it down for winter. Went to fire it up and now I am not getting spark from coil to dist. , So I put on new coil and still not firing up. Have gas and turns over great only 289 hrs on engine. ???? Looks like new points and condenser, cap and rotor and wires
I agree with Goatman. You can check the voltage. I am bullet pointing some ideas and questions so you can copy-paste reply more easily.
This should get you started. Let us know how it goes!
Ayuh,...... Did you service the points,..??
These 4 & 6 cyl engines will corrode the points after long periods of inactivity. I'm not sure if it occurs if stopped with points open or closed is the culpret. Some 180 sandpaper on the points will usually get it running.
