I have a 1985 260 merc with a MR drive. I purchased the complete water pump kit (upper and lower pump housing). My Clymer manual states the torques as follows: Nuts: 60-90 In. Lbs. Screw 30-40 in.Lbs.
It also states for the #1 drive for the 1/4-28 nut: 20-30 in. lbs. and the 5/16-24 nut: 35-40 in. lbs.
It also states Late Models; Aft bolt 20-30 ft.lb and aft and foreward nuts 50-60 in. lbs.
I know the torque specs are important because of the plastic housing. The pump housing I took off is distorted because over tightening.
Where can I find the proper torque specs for my MR pump. Clymer's specs seem vague.
It has two 1/4-28 nuts . One 5/16-24 nut and a long screw.
Thanks, Chuck E.
Thanks, Chuck E.
