rh.campbell
My winter project is to completely redo an 18 HP Mercury outboard which I bought for a song, and is in essentially excellent shape other than the kill switch was disabled by a previous owner. I plan to repaint and install new decals and fix a couple of minor problems (disconnected kill switch and missing anode)
An ohm meter shows continuity when the kill button is pressed across the leads. However, the two leads of the switch are not connected inside the motor. One lead is obviously a ground because it has a metal connecting loop on it, but the other end has a press in connector which goes no where. When I look at the ignition module, I see a black/yellow wire that comes out of the module, but has been cut off about 2 inches long.
My question is this.
I'm assuming it originally went to the other lead going to the kill switch and any diagrams I can find do show a single connection to the motor to shunt the ignition system to ground. Am I safe to connect this unknown lead up to the other end of the kill switch
Is there any chance I could short things out and destroy some part of the ignition system. This old motor doesn't have a lot of spare parts available so I'm reluctant to take a chance. The second owner I bought it from told me he simply choked the engine to turn it off
Can someone assist...many thanks
