1985 150 Black Max Tilt Trim?
Could be the sender is bad,the wiring has a short.The connections?
Unhook the wiring at the motor.
Ohm meter across both leads.
Activate by hand it should make the meter react the same as your guage.
If the wires are intact I have cleaned out old grease in the old style pucks. Scribe a line across both halves and open it, remove the grease, polish the contact surface w/an eraser or LIGHTLY w/1500 grit sandpaper. Reassemble and lube w/ 2-4-C.
Yes. If you have a gauge installed in the dash someone has either removed the sender or swapped engines w/o one.
The engine was swapped out, so I'll check and see if there are mounting holes for the trim sender. It has a trim gauge, but who knows! It is tough to see where the sender actually attaches, is there a way to describe where it goes?
