had my boat down at the river when experenced sudden lose of power. turned out i lost 3 out of 6 cylinders swaped my switch boxes and sure enough had to replace 1. upon installation of a new box it started right up. Took it to the river and sure enough it wouldnt start no spark/
i remove the black and yellow wires from the switch box and it fired right up. so that told me my key switch circuit was at fault and sure enough it was and i replaced it. go to start it and nothing happens i move the pos. cable on the battery and it cranks over and starts but runs a little erratic but runs for a couple minutes and shuts down. go to start it runs and shuts down again. Could this be a battery issue once started can the pos. cable be removed and the motor still run? I also noticed that the 2 yellow wires from the stator to the voltage regulator get very hot is this a problem? Any ideas out there im getting very frustrated!!!!!!! Thanks When it shuts off its not like sputtering it shuts off like shutting it off with the key.
