1985 110hp Johnson Power pack location
mphill47
By process of elimination I ha
By process of elimination I have determined that that lack of spark to two cyliners is a bad igniton module. Can someone tell me where this module is located. I pulled the flywheel and of course found that it wasn't there. thx
"Marc,
Are you sure is a 85 1
"Marc,
Are you sure is a 85 110 Johnson ? I could not match the HP to the year.
Please be sure to do a complete inspection the trigger and stator clean if necessary , and be sure to re-torque the flywheel as per the manual instructions.
Please see the diagram this is for a 115 HP for 85 Johnson your Power Pak is item number 9
Found out it's an'87 m
Found out it's an'87 model and thanks to your diagram have found the power packs. Replace faulty PP and motor runs great.
Thanks for your help !!
"--you would think,...that the
"--you would think,...that the high dlr,engineers,could figure out all the blowing packs,...for the last 35 yrs...........i had a talk w/a factory rep,in early 80's,..he said,..they design the eng to last 5 yrs....they gotta sell parts--was his answer."
"they design engines to last f
"they design engines to last five years,(electronics)are porposley engineered to fail.
i wonder how maney running hours some of these things are built for."
"I think the statements need a
"I think the statements need a bit of modification.
They are designed for lasting at least 5 years.
You want it to last longer, maintenance is the solution. For electronics -keep grounds clean, batteries in order, follow set specifications when it comes to loads and out-put etc.
Powerpacks mainly blows due to 'outside' reasons like bad grounds, defective/wrong spark-plugs, 'jumping' sparks to primary leads, overheat of engine etc. Stator melts and runs too hot due to too high output (Big batteries??) on the charge side....
there are no reasons that they may not run for thousands of hours. Lifetime is very much up to the user."
