Dear Forum,
I own a 1984 Mercury 3.5hp 2 cycle engine, serial number 6298133. After replacing the water pump and reassembling lower unit back to upper portion I noticed the shifting into gear, only two choices, neutral or forward, seems erratic. I had the motor in neutral when removing the lower unit and reassembling after the water pump install. Should I have had the shifter in forward gear? Can someone tell me how to rectify this? If I drop the lower unit again should I do so by first moving the shifter in forward or removing it in neutral position and then putting the shifter in forward and then reinstalling the lower unit with shifter in forward position? Please advise.
