1984 Marineryamaha 40hp lower unit seals
pec
I have a 1984 40 hp mariner th
I have a 1984 40 hp mariner that I straightened the prop shaft. I replaced the seals and o-ring in the lower unit but oil is still pooring out after I start it. Could it be a drive shaft seal.
"small drip of oil coming out
"small drip of oil coming out of prop and exhaust , could it be the seal behind prop and how hard to change this seal. Ray"
"That one is easy: drill a sma
"That one is easy: drill a small hole in the seal, screw in a sheet metal screw and pull it out with pliers.
Jef"
