I recently purchased a 1984 Ma
I recently purchased a 1984 Mariner 9.9 for my small boat. I am wanting to do some pm on it and have a couple of questions. I drained the lower unit. The lube that drained was a green color. I bought some "Super Tech Marine SAE 80W-90 Lower Unit Gear Lube" to replace it with. I noticed that what I bought was not green. Is this the right stuff to replace it with? Also I am wanting to replace the spark plugs. I pulled the old ones and they are NGK B9HS. The guy at advance auto gave me some Autolite 4092 as replacements. Are the orginal NGK B9HS the correct plugs? (Being an older engine I thought perhaps someone may have incorrectly replaced them.) Also what is the correct gap to set the plugs at. Thank you for your help.
