"1984 Force 125 - Dies going i
"1984 Force 125 - Dies going into Reverse
Cleaned and adjusted the carbs so it starts quick and idles good in gear in the water (tied to a dock), if I go back to N then to REV, the engine sputters and dies... Any Ideas ?
Lower unit had the impeller changed and shifts nicely, good comp 120-125 on all 4.
Could the shift linkage need adjusting ? Could the initial timing be off ? the throttle cam is on the mark, but didn't have a timing light with me.
Thanks"
Thanks"
