mfisher0918
I am at my wits end and hoping someone can help. I have a 1984 Evinrude 70hp on a 20ft pontoon boat. It idles fine but falls flat on acceleration. (Only in the water under load). I can "feather" the butterflies and get it to "catch" and then I can take it to full throttle and it runs like a champ. I can also engage the electronic primer to get to full throttle. This motor came off of a 14ft V-hull and runs perfectly on muffs.
Here is what I have done so far:
Rebuilt carbs, also took them back apart twice to double check and make sure everything is clean - it is. These carbs have fixed orifices so no jet adjustment
New plugs/wires
Checked resistance on all three coil packs - Good
All new fuel lines/primer
Rebuilt fuel pump - I believe it is working because pumping the primer bulb during attempted acceleration does nothing
Compression check - 125ish on all three cylinders
Spark test - good spark
Timed and synced per manual with timing light
I have no idea where to go from here. I have spoken to a talented Yamaha mechanic and he also has no answer.
Please help!?
New plugs/wires
Please help!?
