justintime84
Good evening everyone!
I've got questions on this new to me outboard project and am hoping y'all can help me out! I tried finding info specific to my model on here and didn't have very good luck. So here I am making my own post!
So I did a full update on many things. Paint and decals included!
All OEM Parts -
New stator, timer base, power pack, coils, wires, plugs, rectifier, tilt & trim relays and harness, rebuilt fuel pump, rebuilt carbs, all seals and water pump in the lower unit and new gear oil.
I pulled the throttle cable off the timing tree and did the link and sync on the carbs.
Used the piston stop tool to adjust the pointer to true TDC.
I was planning on doing the Joe R method for timing before going to the water to do a field test/timing.
I had my lower unit submerged in a tank almost level to the cavitation plate. I hooked up the timing light with a tach built in on the number 1 cylinder to check my timing and it was showing 2° btdc, although my idle was high about 1800/1900 RPMS. I tried to mess with the timing to get the idle down a bit but it would start dying about 1400 RPMS.
What could be the cause of my high idle?
What is the proper timing for idle and WOT?
What is a good compression reading for these motors? What is a bad reading?
Is there something I may have missed during this refresh that I should be looking at?
Thank you for your time and help with any of this! Excited to get out there on this beauty!
All OEM Parts -
