Stephen Gageant
Hi all,
First post here hopfully you all can help me.
I have a 1984 evinrude 60hp twin (2 stroke) ran it 2 years no issues, last year lost the pinion gear under full power.
Many pieces, no damage to the lower unit housing. Replaced pinoin gear set ( it did seem a little tight when spinning drive shaft).
Thats the back story,
The issue, ever since lower end rebuilt, when it goes to about half throttle total lose of power.
Now I did adjust cables after lower end reinstalled. Though it may be bad gas so replaced gas with fresh non-eithanol 90 octane.
replaced several fuel lines, replaced main fuel line and primer ball. Took carburators off disasembled and cleaned everything.
Test run same problems. Worried maybe magents jumped when drive blew took off fly wheel and check magnets and stators all looked good.
At idle in driveway put a timing light on it and checked timing, adjusted to 3 degrees before top dead. (it was like 3 degrees after top dead, the side with no timing marks). Test run on lake to adjust high side on timing and boat is still doing same thing. total lose of power after half throtle.
Might some thing in lower end be binding up and killing power under load ? it rev's and runs fine until under load??
Also anyone know what the timing should be ?
model E60ELCR
Thanks, Steve
model E60ELCR
Thanks, Steve
