riverdweller2004
"Ok, First of all, I'm new
"Ok, First of all, I'm new here and I'm really glad i found you all. So far, just breezing through the topics has given me a lot of great insight. Now, to the problem. Last season I began to have a problem with my port engine in which after running for a short time, when i would bring the rpm's back to idle, it would stall. I had recently bought the boat, so I figured it wasa good time to give the motors a tune-up. I installed brand new fuel/water sperator units, Replaced the mechanical fuel pumps with Holley marine electric fuel pumps, replaced all of the fuel lines, put all new fresh fuel in the tanks, installed new coils (Mallory marine) / points / plugs / wires / caps / resistors / fuel filter at carbs, and changed the oil and cleaned the flame arrestors. The port motor now runs fine, but I recently began having problems with the starboard motor. First, I have noticed that there is some unburnt fuel comming out of the stbd exhaust. I'm guessing i need to adjust the carb. I am also having a problem in which the motor does NOT want to idle. It runs fantastic from 1600rpm and above, but as soon as it drops below 1600rpm it wants to stall. The tach fluctuates drastically and unless i feather the throttle back up, it actually bogs down. My best guess is that it's the carb. It LOOKs brand new, (Rochester Q-jet). I know this is a long post but I could really use any/all input to narrow down the problem(s). Thanx in advance for any replies."
