Welcome aboard !
Got enough room to get a puller on them ? You might have to take the drive off. On the trailer here is how i do it... drive fully down, i crank the bow down, place a piece of flat wood under the skeg / fin. Crank the bow up till the skeg touch's the the wood. Remove the rubber bumpers they pry off gently, mark them so they go back on exactly as they came off.. exactly understand !
Remove the four screws that hold the bushings Mark them they go back on exactly as they came off. Now with someone else cranking the bow up another inch or two the drive will just lift off the cradle. Spin the drive on the wood or drag it over just enough to get to the ball gears, tie the drive up to the boat. There will be enough play in the cable just be gentle do not pull on the cable at all.
Post back how you made out.
