1984 90hp Mercury coughing
S
Spence
Guest
" I have a 1984 90hp Mercury t
" I have a 1984 90hp Mercury that is "coughing" or making a "splat" sound. I thought it was my #1 spark plug(firing order:1,4,5,2,3,6), so I replace it. That wasn't the problem. Funny thing was, when I removed the wire leading to this spark plug, the "coughing" stopped. I then switched the #1 spark plug wire with the #3 spark plug wire (yes, both ends) to see if my #1 wire was bad. No luck. Lastly, I added more straight gas to my tank thinking maybe my mix was to rich b/c the engine has an oil/gas smoke. Still no luck....Any suggestions,anybody? "
correction on above notes: so
correction on above notes: sound is more akin to an intermittant high pitched spitting sound when it misses or whatever it it doing. and when this occurs white smoke appears to come out of the top of the engine. I appreciate any help you can give me.
IS THIS A TWO STROKE?IF IT IS
IS THIS A TWO STROKE?IF IT IS YOU MIGHT HAVE A BAD REED VALVE
