onemeanfisher
ok, I am stressing a little. I have a 84 Bayliner Capri with a 85 Force Outboard we have had the boat about two years. It runs allright but lately we have had problems starting it, it normally starts up good initially then once we run it awhile it takes a while to start again.But after about 10 minutes or so cranks right up.
I thought it might be a cracked hose so I replaced all hoses( gas & Vacumm) same thing kept happening. So we got a bright idea to take it to a boat mechanic and get all 3 carbs re-built, we spent 200 bucks ( along with a new stainless steel prop repair and a transom saver built) The short of it we spent 600 bucks for all that.
Well as you can imagine we are excited to get it to the water a test it, new prop, carb re-build it's gonna run great. we get to the water and it starts fine but when put it in gear and you give it the gas it dies!!! runs fine in idle and you can even reave it up in neutral and it runs fine but once it goes into gear it dies.
Well I took it back to the mechanic to fix it AGAIN. He comes back and tells me it looks like your motor is blown because the cylinders will not hold pressure. Now my first question is Does a cylinder hold pressure or once the cylinder dropped down or fires doesn't the pressure subside??? It shouldn't hold steady pressure right???
Well I tested it myself with a compression gauge( didn't have the capability to see if it help pressure or not!!!) The top cylinder hits about 120, the middle cylinder about 129 and the bottom cylinder about 119, 120. Is there a problem with the 10 pounds difference on the middle one???
Here is what I have been told, 10 pounds makes a BIG difference and it's probably a fuel or spark issue and has nothing to do with a motor blown, mechanic just doesn't want to deal with it and telling me it's blown it saves him the head-ache. Is this motor done?? Or should I take it to someone to re-build the carbs again?? Or just trash it and find another motor??? Thank you for your help I am at a crossroads
