"Hi to everyone, new to the si
"Hi to everyone, new to the site , and looking for some help with my 75 merc. I bought this motor with a 16 ft Starcraft ss 160 this fall. I did not get a lot of history with the the purchase. The motor looks in good shape, but the prop was pretty beat up and there are a few nick and gouges in the skeg. I ran the engine in a drum of water, but it was hard to start and idled very rough. It went into forward and reverse smoothly. I decided to replace the water pump as a percautionary measure. After removing the LU I noticed there was a fair amount of up and down movement in the drive shaft ( no preload pin). After removing the water and base I was suprised to find no shims. I mearured as per the manual and inserted the proper thickness of shims then the pump base and still hat roughly the same amount of up and down play in the frive shaft. I removed the pump and base again and this time pulled out the upper driveshaft bearing cone and it is very badly worn, no more shine just a dull surface. Is it safe to assume the bearings and gears worn enough that the shaft has dropped down not allowing preload on the bearings?
I also did a compression test on the powerhead today and found them to be starting from the top down 140, 130, 140, 140 is this good? The other thing I noticed was the spark plug in #2 cyl has erosion of the whiter ceramic around the electrode, is this normal, and what would cause it?
I have included a couple of photos. the second photo of the plugs #2 is the second from the left.
