MichielvdLans
Howdy folks,
I bought recently an old Evinrude 6HP which did't ran well. And didn't pump water at all. The carb clean was an easy fix but the waterpump caused me some headaches!! In fact, the drive shaft was seized in the crankshaft /powerhead so I needed to disassemble a lot!!![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Luckily the impeller key was already missing / thorn to pieces because while I separated the tail I didn't trashed my waterpump housing because the key was still in there.
I left it soaking for a week in penetrating oil, wd40, trashed a pair of vices but eventually the bugger came loose!! Oufffffff!!![Cool :cool: :cool:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Some pics of the whole operation:
Ofcourse one bolt snapped to make matters worse.......
Ready for assembly:
While dismantling the exhaust cover I found a badly deformed grommet that goes somewhere around the water tube. Since I couldn't locate the right spot and the grommet was wasted anyway I left it out. Used Hylomar to get the whole bottom leak free so I suppose my engine isn't going to miss that grommet. Does anybody knows where that grommet actually belongs? The watertube is tight in the aluminium housing and there's a gasket between the cilinder block and the exhaust.
![p5pb14159346.jpg](http://ep1.pinkbike.org/p5pb14159346/p5pb14159346.jpg)
![p5pb14159285.jpg](http://ep1.pinkbike.org/p5pb14159285/p5pb14159285.jpg)
Ready for assembly:
![p5pb14159286.jpg](http://ep1.pinkbike.org/p5pb14159286/p5pb14159286.jpg)
![p5pb14159287.jpg](http://ep1.pinkbike.org/p5pb14159287/p5pb14159287.jpg)
![p5pb14159289.jpg](http://ep1.pinkbike.org/p5pb14159289/p5pb14159289.jpg)
![p5pb14159282.jpg](http://ep1.pinkbike.org/p5pb14159282/p5pb14159282.jpg)
