Tiburon_cuba
Hello there!
I am a newbie in boating. I have spent some time doing some maintenance in my outboard (J60ELCRE) Johnson 60 HP 1984 after it was seating for almost 2 years, I just bought the boat with this motor. I replaced the water pump, the seals of the lower unit close to the water pump, spark plugs are new (Champion L77JC4), put new spark plugs wires, rebuilt the fuel pump, rebuilt the prime valve (solenoid), took out the carburators and cleaned them. The motor starts very well (not like a car but pretty easy) the problem is that when i am going to put it in gear it stalls some times, other times i can shift it but does not go, it is like is idling, some times gets some more RPMs and goes back to low RPMs, it has no power, all this with WOT. I have been reading here and in other websites but havent found an explanation to something like this. While in the water i tried to adjust the timing, thinking that could be it but didnt make any difference. The gas is fresh from today, the mix is 50:1 as recomended in the manual.
Please, if you have any suggestions let me know, any help will be very appreciated.
Boris.
Boris.
