Head is still off and wondering do I button it back up with the new gasket, or recommend an overhaul? Piston clearance at top of ring travel is about .011 on both cylinders.......ouch! Wouldn't we like to see about .06 to.08 max? I pulled the head suspecting the gasket leak and the customer is wondering if the motor would be useable if I put it back together.....maybe gaining enough compression in the infected cyl. by replacing the gasket. I priced the overhaul out at about $1,000, going .030 over. The motor is really nice otherwise......overall condition......not a "junker". Like you say, the pistons are pretty loose until the engine would be warmed up. I measured the clearance at about 45 degrees F. Compression test was done cold as well. Now I would have to sacrifice the $44 head gasket to provide another compression test.......after warming up the motor. There are no signs of overheating, but he said that it did overheat once on the previous owner and the water pump was replaced. No word on what the water pump really looked like. Thanks, Guido
