1984 4cyl 75hp idling
joediv
I think the idle is a bit too low and I want to make sure, is there an inexpensive multi meter that is simple ( for my simple mind) that I can buy to adjust carbs or should I muck with the advance ? I'm really not that confident on my ability to do the latter. I could also use to see a manual if there are any on the web.Thanks
DON'T adjust timing stop to change idle speed! There is a Idle Stop which can be adjusted to raise idle speed. You'll likely have to readjust the throttle cable for proper tension, after changing idle speed. Not to be confused with the "Throttle Stop" which is another adjustment for maximum carb butterfly opening.
There is an idle mixture screw on each carb, by which the mixture at idle is adjusted for, rich or lean. Adjust each screw for smoothest operation, idling in gear, fully warmed motor, in the water. Once you find the "extreme lean" range of each mixture adjustment, i.e. when you're screwing the needle "in" (Clockwise-lean) and the engine is going to die, turn the idle screw about 1/2 turn to the rich (CCW). This is a good basic adjustment and if you have a good "hole shot" without bogging down, pretty close. If the engine "bogs" upon acceleration after adjustments, turn each screw another 1/8-turn to the rich (CCW).
That oughta do it! "Spark Advance" or "Spark Stop" do not affect idle speed and should not be adjusted unless you're setting maximum spark advance. Get a manual for that.
HTH...........ed
I'm curious if you have any other symptoms other than a low idle? I've been struggling with mine (exact same engine), screws are right around 1.5 turns out. Timing looks OK, best I can tell. But the darn thing won't idle, it struggles in mid-range. When I say struggles, at around 1/2 to 3/4 throttle it lugs/chugs and doesn't accelerate. Once I manage to get it past 3500 RPM it opens up and runs right close to 5000. If I just open it up it dies, I have to work my way up to WOT very slowly through mid-range. And it doesn't feel like it has the power it should.
