"The engine won't crank wi
"The engine won't crank with either the ignition switch, jumping the starter solenoid or directly by passing the solenoid from the battery directly to the starter. It was cranking fine, now it's so weak it can't even turn the engine over. When I tried the last two options the number two coil (that I bought brand new from MarineEngine.com) started smoking! Help? I'm afraid I fried the coil. This may sound obvious, but could it be the solenoid and not one of those (expensive) starters?"
