1984 20 hp johnson no start
btduckcall
"am wondering what the ohm sho
"am wondering what the ohm should be coming out of the power pack have nothing seems coils ohm ok, but no fire to plugs."
"Billy.... Sidestepping your q
"Billy.... Sidestepping your question momentarily as I don't have the service manual in front of me, The problem you're having is usually due to a failed powerpack.
Having said that, it's a very good idea to always have a spare powerpack in your boating tool box along with the tools to replace it. Powerpacks can fail without notice which can really ruin an outing. I'd suggest that you purchase a new pack for this reason and install it as a test to either cure the problem or emliminate the pack as being the problem.
But first, disconnect the push kill button on the engine to eliminate the possibility that it has shorted out. Remove the black/yellow wire from the powerpack temporarily to eliminate any possible shorts within the wiring harness.
If the engine is electric start with a key switch, unplug the wiring harness at the engine to eliminate any possible shorts within the instrument wiring harness. A shorted igniiton switch can be tested simply by disconnecting the black/yellow wire at the switch.
Let us know what you find."
"already checked the kill swit
"already checked the kill switch first thing i thought of, so guess it is the power pack, just didnt want to spend 60 bucks on something i might not need that is why i was wondering how to ohm it, i got no readings what so ever out of it, so guess that is where the problem may lay. thanks"
"tried a new power pack and st
"tried a new power pack and still no fire at plugs, even tried again with kill switch disconnected nothing? any ideas,"
