1984 15hp Johnson outboard question
A
Adam H
Guest
"My girfriends grandfather can
"My girfriends grandfather can not do the pull start any more . Is thre a conversion kit to make it an electric start? And where can I find this kit if there is?
Sure appreciate any help you may be able to lend,
thanks
adam"
yes there is but if you put a
yes there is but if you put a starter on this motor look to install a charge coil to charge the batt jonson dealer or used part shop (ebay mabee ask dealer for parts no day use to make them
Adam... It appears that the el
Adam... It appears that the electric starting kit for that engine is still available . The original part number is 174549 but has been superseded up to part number 174974. Expect the price to exceed $400.
Thanks for the information guy
Thanks for the information guys ...I will check into it. Maybe a new motor is in order..
adam
