1983 mercury 70hp fuel pump
If you don't see a spring, then you probably don't need it. The kit probably gave you more than you needed just in case. you shouldn't worry about it.
Is everything else running fine?
Put new diaphragm in and check valve still not getting enough fuel pressure left the spring and plastic cap out and cannot figure out where the spring would go. any help would be great thanks
