blackdog1970
Hello, Looking for some insight on a water blockage issue in the the water tube. I have replaced the water pump. I'm getting water pumping through water pump as I hooked up a drill to drive shaft and water pumped after kit was installed. No water pumping after reinstalling lower unit. Next step was removing rubber hose from the fitting on the side of the motor that connects to another fitting at bottom rear of motor housing which I'm guessing connects to the water pick up tube. Water pumps out of fitting on the side of the motor. Next I reinstalled hose on vertical fitting at rear of motor case and tried blowing through that and it's plugged. Tried blowing some air through the hose which blew it off the fitting. So I believe that is where the blockage is just not sure how to clear it. Took a wire and put in the fitting but it must make a quick turn because it didn't go in that fitting very far before it stopped. Any and all help would be greatly appreciated.
