"Just rebuilt completely my mo
"Just rebuilt completely my motor. Cranks and runs fine except after being run a while and I stop for a while then try to start and it won't. Seems flooded. I have gone thru carbs changed all fuel lines, replace tank line. The tank is 40 years old. I am suspicious of the sending unit on the tank but I do not leave the tank hooked up to the motor to rule it out. I took apart the fuel pump and bought a new kit for it. Unfortunately it
does not work due OMC changing the old parts over to a slightly smaller pump. The Johnson dealer I buy my parts from said they had seen this problem before on pumps this age. Inspection of the pump parts really shows no problem just replacing gaskets etc to rule this part out. Cranks fine if the motor sits for a long time. Have check fire to plugs in the dark and all three are bright blue
coming off the plugs. Help what am I missing."
