jeffasmith
"Folks, I have a small concern
"Folks, I have a small concern with the voltage readings from my 70HP Johnson and would appreciate your guidence. Current readings from the fish finder (which has a volt display on it) the volts at idle at 12.8 ish. At 5500 RPM (I think the tack uses the same for its readings)it is 14 - 16 volts. Is this a problem? With the rectifier?. Originally the volts used to only get to 14 at 5500RPM. Last year when this started I notice my deep cycle battery was making bubbling sounds. So, I replaced the battery this year with an even larger deep cycle battery and the readings remained the same. Appreciate your thoughts!"
