Hello all,
I have a 1983 Johnson 7.5 short shaft that runs beautiful. I do however think it may have heating issues because when I put a Temp gun on the head while it is running in a tank, it is getting up over 170 deg. I have tried this in gear and in neutral with roughly the same results.
I don't know if it goes much higher as I usually turn it off.
I replaced the water pump and thermostat. When I remove the thermostat it runs cooler but the head near the spark plugs still is getting up to 160 deg range. When I remove the the thermostat cover and run the motor lots of water is pumping.
I am concerned because I do not see much water coming out of what I believe is the exhaust (half way down the back of the leg.
I see some a little 2 stroke smoke when it's cold and it does spit a bit when it warms up but not the amount I would expect. This leg doesn't look like it exhausts through the prop.
Does the exhaust come out the back of the leg half way down like other motors ?
Should I expect to see more water or not alot ?
Am I being to concerned about nothing ?
