Hi guys,
My motor: 1983 Johnson 25 hp, model: J25RLCTE
Last year I had issues of water getting into my lower unit, so I decided to replace the water pump and the seals. When I was pulling off the water pump housing, it ended up pulling the drive shaft up out of the lower unit. I discovered that whoever last replaced the water pump installed a few things incorrectly.
Now to my question; since the drive shaft got pulled out, do I need to open up the gear case to line up the drive shaft with the pinion gear? According to the service manual you should, but I put the drive shaft back in and everything seems to be working correctly. (Shifting in and out of gear, turning the drive shaft turns the prop shaft in both forward and reverse, and it doesn't sound like there are any loose parts rattling around down there. )
Has anyone had this problem before?
Thanks!
Thanks!
